Network segmentation - switch level
carl_townshend
Hi All
I am looking at doing segmentation for my corporate and OT/IOT devices etc.
Is it trustsec and Cisco ISE that does this?
We have mainly 2960X switches at the edge, can these do SGACLs ? if not would the access need to be blocked further down the network on a device that can do the enforcement?
Cheers
It appears to be so. It is not supported on the 2960x series.
Reza Sharifi
Hi Carl,
It appears that SGACL is only supported on the 3850 and 3650 series switches.
see table-1 in this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/security/configuration_guide/b_sec_152ex_2960-x_cg/b_sec_152ex_2960-x_cg_chapter_010100.html
Does this mean we could not do it at the edge ?
