Network/Voice packet sniffing tool
I need a free tool that isnt wireshark that will let me sniffing voice packets from a cisco phone when I plug into a cisco switch using span. Any suggestions what free software is out there I can use besides wireshark.  I need to determine by analyzing voice packets such as UDP or RTP,etc.  where those packets are been dropped in my network, such as a switch or on the ISP side.
Thanks.
5 Replies 5
Bilal Nawaz
Hello, you could look at these:
http://www.layerview.net/
http://www.nirsoft.net/network_tools.html
http://technet.microsoft.com/en-gb/sysinternals/bb897437.aspx
Wireshark is pretty comprehensive though. Was there any reason to avoid using wireshark? :-)
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Bill,
Out of those websites you gave me which tool will be able to capture voice packets to analyze accross the network from one cisco phone to another cisco phone to determince where those packets are been dropped?
Reza Sharifi
Hi Reza,
Will this tool be able to capture voice packets to analyze accross the network from one cisco phone to another cisco phone to determince where those packets are been dropped?
VoIP packets use UDP/RTP to transport. So, yes, it will capture all UDP/TCP comm ports.
