TACACS Doesn't work via Telnet/Works via Console
rkallas
I have a pair of OLD Cat6500's running CatOS:
WS-C6509 Software, Version NmpSW: 7.6(16)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Dec 22 2005, 16:37:19
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k8.7-6-16.bin'
System Configuration register is 0x2
I know these are no longer supported, but I have to ready them for migration.  Recently a problem began with these switches.  What happens is that when I telnet to them, I cannot authenitcate via TACACS.  This works fine for all our other IOS equipment, just not for these 2 switches.
The error is:" % Error in authentication"  and then I get kicked back to the login prompt.
The odd thing is that when I connect to the switch via the console port, I can authenticate fine with TACACS.
CMS> /c 14
To disconnect enter: ^X
Buffer scroll mode:
<SPACE>-Next Screen, 1-Scroll All, 2-Skip/Connect, 3-Erase/Connect ...
Buffer data skipped - Port connected.
Username: ca2l
Password:
Core-A-600> (enable
Does anyone have an idea of what may be causing this?
Ray
abel.ortgea
1.- check the TACACS group you have define for console and vty sessions is the same,
2.- In your ACS check the log when you try to connect from the 6500 we can have a better idea of what's happening
3.- check your TACACS key password match with the one you have written in your ACS
4.- you need a local user password in your 6500 it maybe was deleted
  The setup should look like this .  If you need tacacs on the console obviously turn that on .
set tacacs server x.x.x.x primary
set tacacs attempts 3
set tacacs directedrequest disable
set tacacs key XXXXXXXXXXXXXXX
set tacacs timeout 3
set authentication login tacacs disable console
set authentication login tacacs enable telnet primary
set authentication login tacacs disable http
set authentication enable tacacs disable console
set authentication enable tacacs enable telnet primary
set authentication enable tacacs disable http
