New to networking, Hardware question
mhoffmann25
Hey all!
I've just started with networking and was wondering how you know if the device you are working on is a router or a switch. Do you show version and look up the model number on google? I have had some confusion because I know there are some L3 switches that will do routing. I'm just trying to not look like I'm too much of a newbie.
Thanks for any replies!
Leo Laohoo
The quick-and-easy way, yes.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Actually any L3 switch should be capable of routing, that's what makes it a L3 switch.  Of course, a L3 switch might not be configured to route, i.e. it could operating just as a L2 switch.
. . . how you know if the device you are working on is a router or a switch.
You might go by what the manufacturer says, but they can confuse the issue depending on how they want to market the device.  For example, Cisco's 6500 was sold as a L2 switch, while its 7600 was sold as router, yet they could use the same supervisor, the same line cards, and the same software.  Different labels on the chassis, though.  ;)
Generally a L2 switch cannot route packets, a router cannot switch frames, while a L3 switch can do either.
