Nexus 3048 upgrade Path 7.0(3)I7(7) to 9.3(11)
ddjames
I intend up upgrade our Cisco Nexus 3048 Switches from 7.0(3)I7(7) to 9.3(11) and am curious if I can go for a straight upgrade or if I will need to go to another verision first? These switches are using HSRP between each other and serve as our main gateway to the internet.
6 Replies 6
ddjames
If I'm reading that correctly, we shouldn't have to upgrade to 7.0(3)I7(8) as an intermediate step-up as we are past the verison it specifies, 7.0(3)I7(6). One thing that isn't as clear from reading this, would we need to upgrade with the compact image, or standalone. There's a pretty significant difference in file size between the 2.
Cisco Nexus 9000 and 3000 ISSU Support Matrix <<- did you check matrix ?
there is path and many alternative path,
Ah, I see the 7.0(3)I7(7) → 7.0(3)I7(10) → 9.3(11) path listed in there.  Would I be able to get away with using the compact images then? or would I have to download the full image to upgrade?
I see your Q but relay I dont full sure that I can answer or suggest you which one is OK for your case.
sorry can you put it in separate post.
thanks
MHM
