Nexus 5000 interface vlan ping
opnineopnine
Hi all,
I have two 5000 on different sites, connected via dark fiber, I have this interface in mode trunk and I allowed all vlans.
When I do a show cdp neigh I can see both devices, but when I do a ping between sites I loose all my packets.
Any ideas?
thanks.
8 Replies 8
Reza Sharifi
Is the source and destination IPs configured correctly?
Can you provide the config for the vlans and the IPs?
Hello Reza,
Site 1
vlan 60
inter vlan 60
ip add 192.168.1.10/24
Site 2
vlan 60
inter vlan 60
ip add 192.168.1.14/24
Thanks!
And vlan 60 is added to the trunk between the 2 switches?
Are the interfaces in up and up mode on both switches?
sh ip interface vlan 60
Yes the trunk is a trunk vlan all, and the interfaces are up.
thanks.
Can you ping using the source interface?
site 1
ping 192.168.1.14 source 192.168.1.10
I dont get any answer, but if I do a trace.
traceroute to 192.168.1.10 (192.168.1.10), 30 hops max, 40 byte packets
 1  192.168.1.14 (192.168.1.14)  0.852 ms !H  0.384 ms !H  0.218 ms !H
thanks.
Since these are 5ks, it inter-vlan feature enabled on both switches?
I found that the issue is spanning tree that is blocking on one side in the interface that I use for the dark fiber I added , but still the same issue.
interface Ethernet1/31
  switchport mode trunk
  spanning-tree port type network --- added
thanks.
