NEXUS 5000 LICENSED FEATURES NEED ATTENTION!!
san ju.
Hello Team,
I wanted to bring to your attention that one of our Cisco Nexus 6001 switches (System version: 7.1(5)N1(1)) is displaying a notice stating "NEXUS 5000 LICENSED FEATURES NEED ATTENTION!!" I understand that when the license for conditional features expires, those features will be disabled. However, I would like to clarify if this will have any impact on the overall functioning of the switch. Additionally, could you please guide me on how to check the conditional features that are currently enabled on the device?
Thank you for your assistance.
Best regards,
For the features enabled check the "feature" part of configuration.
BR
****Kindly rate all useful posts*****
johnlloyd_13
Level 9
Level 9
hi,
per the screenshot, please contact/raise a cisco TAC case to assist you moving forward.
san ju.
Hello team,
Thank you for your valuable responses to my question. I appreciate your helpful insights and assistance. By the way, if you want to check the active and enabled features on your device, you can use the command "show license usage." It's a simple way to get a rundown of the license usage and see which features are currently active.
# show license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FC_FEATURES_PKG               No    -   Unused             -
VMFEX_FEATURE_PKG             Yes   -   Unused never       -
ENHANCED_LAYER2_PKG           No    -   In use             Grace 22H 39M
NETWORK_SERVICES_PKG          No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use never       -
LAN_ENTERPRISE_SERVICES_PKG   No    -   Unused             Grace 3D 8H
**** WARNING: License(s) about to expire, licensed features will be DISABLED. ****
San ju.
