Nexus 5500 Port-channels down on ASA 5500 interfaces
Rodrigo Belo
Hi all,
After upgrading NEXUS 5548 switches from version 6.0(2)N2(4)  to version 7.0(5)N1(1) a few port-channels did not come up (diagram attached).
Funny enough, those port-channels that stayed down are all connecting Cisco ASA 5525 Firewalls. I have another firewall connected to those switches (Cisco ASA 5515) and had no issue with that one.
The NEXUS are on a vPC domain and every port-channel is vPC with LACP.
All Port-channels are configured the same way, on the NEXUS side and on the Firewalls side.
6 Replies 6
Dear Rodrigo,
Could you please share the below output from bothe the nexus switches. Also please share the relevant logs if you have any.
sh int po<>
sh int <member ports>
sh run int po <>
M
Hi Madhukrishnan,
unfortunately I had to roll back because this is a Data Centre production infrastructure.
Attached is the output you requested but beare in mind that it`s from version 6.0(2)N2(4) where everything has always worked fine.
Did you happen to collect the logs at the time. If so we could take a look at to see what was going on.
Also one thing you could have checked was whether the interface staying up individually  or not out of PO.
M
Hi Madhukrishnan,
Troubleshooting revealed that there was an issue with LACP negotiation, which I'm not quite sure what it is.
If we configure the port-channels to mode "on" everything works well...which is something I really don't want to do.
Never got to fix it but I will soon upgrade the ASAs and NEXUS and let you know how it goes.
cheers
Thanks for updating Rodrigo
Rodrigo Belo
Finally found the issue...counterfeit SFPs!!
The fact that the only interfaces failing were the ones connecting the ASA 5500 was just a coincidence.
