04-20-2013 05:34 AM - edited 03-07-2019 12:56 PM
I need some help
How to you setup ip routing on a Nexus 5500
I want to do vlan routing between an Nexus 5500 and Catalyst 3750. Nothing clever just have the 2 switches talk and vlans route between the two.
Dave
04-20-2013 06:03 AM
Hi Dave,
First thing you'll need to confirm is that you have a Layer-3 module in the Nexus switch, you have the license for it installed and it's enabled. You should be able to see this with the show module command and look for something along the lines of N55-D160-L3.
Then which routing protocol are you going to be running? In NX-OS these are not enabled by default so you have to enable the protocol you want with the feature command e.g., feature eigrp, feature ospf etc.
When you've enabled the routing protocol, then you need to enable the interface to the Catalyst switch as a routed interface. The difference between NX-OS and the Catalyst 3750 IOS is that you run the ip router
interface ethernet 1/1
description Link to C3750
no switchport
ip address 192.168.1.1/30
ip router eigrp 1
The routing protocol itself is pretty much the same as standard Cisco IOS devices, for example:
router eigrp 1
router-id 192.68.2.133
default-metric 10000 20000 255 1 1500
redistribute static route-map STATIC_TO_EIGRP
Hope that helps.
04-20-2013 06:19 AM
You can also run certian routing protocol commands under the interface in IOS as well. Similar to the Nexus.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
04-20-2013 06:13 AM
Hello, most of it is the same as any other IOS router/switch.
An example of a simple point to point OSPF neighborship with the two, on a particular vlan (a routed vlan) and the physical interface will itself be a trunk, lets say we have a 3750 on gi1/0/1 connected to Nexus5k e1/1
3750:
conf t
vlan 100
interface vlan 100
description ***Routed VLAN to Nexus5k***
ip address 100.0.0.2 255.255.255.252
ip ospf 1 area 0
ip ospf network point-to-point
interface gi1/0/1
switchport
switchport mode trunk
Nexus5K
conf t
feature ospf
feature interface-vlan
vlan 100
interface vlan 100
description ***Routed to 3750***
ip address 100.0.0.1/30
ip ospf 1 area 0.0.0.0
int e1/1
switchport
This way we have a trunk, and a vlan where we will have a point-to-point adjacency. This does require you to have the layer 3 license on the nexus5k and the correct feature set on the 3750. You can then redistribute your vlans or advertise them however way you need to...
Hope this helps
