Nexus 5548UP w/FCoE QoS Configuration
Mierdin21
I am looking to implement a QoS policy on a pair of Nexus 5548 UPs. FCoE is a factor here. I have created the following configuration and would like to get a few pairs of eyes to take a look at this for a quick sanity check.
I'd appreciate a quick look at this to help make sure this config is valid. Also, I realize I'm applying an MTU of 9216 to all classes right now, this will be phased out incrementally.
class-map type qos match-all class-platinum
  match cos 5
class-map type qos match-all class-gold
  match cos 4
class-map type qos class-fcoe
  match cos 3
class-map type qos match-all class-silver
  match cos 2
class-map type qos match-all class-bronze
  match cos 1
class-map type queuing class-platinum
  match qos-group 5
class-map type queuing class-gold
  match qos-group 4
class-map type queuing class-silver
  match qos-group 3
class-map type queuing class-bronze
  match qos-group 2
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type queuing class-fcoe
  match qos-group 1
policy-map type qos system-level-qos
  class class-platinum
    set qos-group 5
  class class-gold
    set qos-group 4
  class class-silver
    set qos-group 3
  class class-bronze
    set qos-group 2
  class class-fcoe
    set qos-group 1
  class class-default
policy-map type queuing egress_queueing_policy
  class type queuing class-platinum
    priority
  class type queuing class-gold
    bandwidth percent 20
  class type queuing class-silver
  class type queuing class-bronze
  class type queuing class-fcoe
    bandwidth percent 0
  class type queuing class-default
    bandwidth percent 40
class-map type network-qos class-platinum
  match qos-group 5
class-map type network-qos class-gold
  match qos-group 4
class-map type network-qos class-silver
  match qos-group 3
class-map type network-qos class-bronze
  match qos-group 2
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
policy-map type network-qos system-level-qos
  class type network-qos class-platinum
    queue-limit 30000 bytes
    mtu 9216
    set cos 5
  class type network-qos class-gold
    mtu 9216
    set cos 4
  class type network-qos class-silver
    mtu 9216
    set cos 2
  class type network-qos class-bronze
    mtu 9216
    set cos 1
  class type network-qos class-fcoe
    pause no-drop
    set cos 3
    mtu 2158
  class type network-qos class-default
    mtu 9216
    multicast-optimize
system qos
  service-policy type network-qos system-level-qos
  service-policy type qos input system-level-qos
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output egress_queueing_policy
Hi Matt
few Qs:
1) Dont U think that while U have "fcoe-default" queuing input policy U will operate only with two qos-groups (0 & 1) by default?
2) Dont U think that definition for queuing on egress for class-fcoe leaves nothing for FCoE in worst case (I mean band per 0)?
3) finally, why U set cos N in the network-qos policy while your network-qos classes are matched with qos-groups and therefore already must be mutched and marked with qos input policy?
