10-14-2013 06:09 PM - edited 03-07-2019 04:02 PM
I tried to copy from FTP to bootflash in NX-OS kickstart 5.1(3)N1(1) (The corresponding system image is too old to support 5596T I can only get into kickstart and booting system image results in crash). It can connect to the FTP server and says saving to disk, but it actually only does the authentication but not downloading or saving. No error message, everything looks fine, just nothing saved to disk.
Is this anything I am missing?
Btw in NX-OS console, why new line is not correctly generated? For example ? will overwrite the existing line.
10-14-2013 07:47 PM
Why would you be trying to copy a kickstart image that doesn't support your platform? The 5596T requires 5.2(1)N1(1b) or later. (reference - see just below Table 9). That applies to both the kickstart and system image.
10-14-2013 11:28 PM
The kickstart image seems to be working fine except that it can't save in copy command. I wonder if there's some kind of catch here. Haven't tried to the same thing with a newer kickstart.
