Nexus 5K Layer 3
slizarraga
Level 2
Level 2
I am buying a Nexus 5K (N5K-C5548UP-FA) with the layer 3 card (N55-D160L3 - Nexus 5548 Layer 3 - Daughter Card).
The switching capacity of it is 960 Gbps but I know I should expect less doing the Layer 3 function  (it will only be used with static routing).
What switching/routing capacity should I expect? How can I estimate it? What else should I consider?
Thanks!!
Sergio
Reza Sharifi
The layer-3 forwarding capacity is 160Gbps with 240,000,000 mpps for all 48 ports witch is equal to 5000,000 mpps per port.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
