I'm looking to expand our management addressing and possibly move the MGMT0 connection that is connected to two Nexus 5548 switches. The management is handled by the Management VRF. The Keep-Alives will fail, but the Peer-Links will remain up and operational. While making changes to the MGMT interfaces and keep-alives, will service be affected?
Solved! Go to Solution.
There isn't any problem to do this changes.
For most security, I'd do it on a little impact moment.
You must be sure the peer-link will never disconnect while you are making the changes.
Best Regards.
Best Regards.
Thanks Iker!
You are welcome.
