Nexus 7000 bandwidth control
liveshell
On Nexus 7000s I want to limit bandwidth of particular IP.
I can do this using proper configuratio of IP ACL, policy map and class map.
But what if I dont have information on interface?
Can I apply bandwidth control for particular IP without knowing the interface?
5 Replies 5
AhmedSonba
I would love to help you out but please can you explain more about what you are trying to
achieve here maybe we can help you out in another way.
Ahmed Sonba
Hi Ahmed,
I want to apply QoS (bandwidth control) for perticular IP (not to all under particular interface) in Nexus 7000s.
For applying QoS , needed configuration includes,
-- creating IP ACL
-- configuring policy map using police to control bandwidth
-- Applying policy map to Interface
Now for me issue is...i dont know the interface name. It can be solved either by
1) If there is any way to get interface name of particular IP
2) If there is other way to apply QoS to control bandwidth without using interface.
any suggestion/solution ?
Wireless > QoS > Profiles > click on a profile to edit and change the rates as required of the "Average Data Rate".
Go to WLAN > choose the SSID to edit > QoS tab > and choose the QoS you desire to use.
Serpent2010
is this has been resolved for you?
