09-16-2011 08:09 PM - edited 03-07-2019 02:16 AM
how do I assign interface to VDC?
I did following:
vdc Vdc-3 id 3
allocate interface Ethernet8/2
but I got following error:
Please make sure that all members of the port-group are part of the command at '^' marker.
and inteface didn't get assigned. please advise.
09-17-2011 07:07 AM
it looks like to are trying to allocate an interface that is either part of a port-channel, or vPC, check your config.
09-17-2011 03:27 PM
Is Ethernet 8/2 on a M132 line card? If this is the case, you have to assign all members of the port-group into a VDC. Meaning E8/2, E8/4, E8/6, E8/8 into VDC 3.
This is because the architecture of the M132 line card, ports are 4:1 over-subscription in a shared mode (one port-ASIC controls 4 ports).
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/Data_Sheet_C78-437757.html
HTH,
jerry
