Nexus 7000 v6.2(10) - OpenSSH MaxAuthTries Limit Bypass Vulnerability
alex.sykes1
Hi All,
We are running Nexus 7000's - v6.2(10) - and a Nessus scan is reporting this vulnerability:
The solution says to upgrade to OpenSSH 7.0 or later.
Do you know how I would do this?  Is an OS upgrade required or is there anything else I can do?
Many thanks in advance.
Kind regards
Alex
Seb Rupik
Hi Alex,
You would need to install new NX-OS software.
Incidentally if you need to check the current version of openSSH just telnet to port 22 .
With the ASA, Cisco publish opensource licence info:
http://www.cisco.com/c/en/us/support/security/asa-5500-series-next-generation-firewalls/products-licensing-information-listing.html
...sadly with the Nexus, this information is lacking and not very up to date:
http://www.cisco.com/c/en/us/support/switches/nexus-7000-series-switches/products-licensing-information-listing.html
cheers,
Seb.
Seb Rupik
Hi Alex,
cheers,
Seb.
Hi Seb,
Thank you so much for your quick response, it really is appreciated.
Thanks also for the tip to find out the openSSH version.  I've been looking for a good way to fund that out for a while.
Kind regards
Alex
Hi All,
I have the same problem on nexus 9504 running latest 7.0(3)I1(3) and security scan showing the same vulnerability: openssh maxauthtries bypass.
I can see no license information available for 7.0(3)I1(3).
How to fix this  vulnerability?
Best Regards,
Mohammad Taamneh
