NEXUS 7000 zombie module on startup-config
Rosa Ladera
During a sw upgrade, 2 NX2000 were removed from NX7000.
After this, startup-config shows NX2000 interfaces in spite of the fact that fex and port-channel configuration were not present any more.
How can i remove NX2000 interfaces configuration from startup config file?
Thanks in advance.
Rosa
Rosa,
you can make a backup of the startup config first:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/4_2/nx-os/fundamentals/configuration/guide/b_Cisco_Nexus_7000_Series_NX-OS_Fundamentals_Configuration_Guide__Release_4-2/Cisco_Nexus_7000_Series_NX-OS_Fundamentals_Configuration_Guide__Release_4-2_chapter8.html#con_1240230
5 Replies 5
Hello Rosa,
if you do a 'show vdc detail' there probably is more than one VDC being displayed. Try and delete everything but the default (vdc1), which cannot be deleted.
Switch#conf t
Switch(config)#no vdc vdc-name
Refer to this document for more info:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/virtual_device_context/configuration/guide/b-7k-Cisco-Nexus-7000-Series-NX-OS-Virtual-Device-Context-Configuration-Guide/managing-vdc.html#d9295e1168a1635
Hi!
Unfortunately there is just one vdc - default one.
nx7000-wc0# sh vdc detail
Switchwide mode is m1 f1 m1xl f2 m2xl f2e f3
vdc id: 1
vdc name: nx7000-wc0
vdc state: active
vdc mac address: 00:26:98:13:43:c1
vdc ha policy: RELOAD
vdc dual-sup ha policy: SWITCHOVER
vdc boot Order: 1
vdc create time: Thu Apr 28 01:47:47 2016
vdc reload count: 0
vdc uptime: 153 day(s), 14 hour(s), 17 minute(s), 5 second(s)
vdc restart count: 0
vdc type: Ethernet
vdc supported linecards: m1 f1 m1xl m2xl
nx7000-wc0#
Rosa,
have you tried a 'write erase':
Switch#write erase
Not yet!
I am litle bit coward.
Rosa,
