Nexus 9k Switches - vPC config
toprock1970
I have a pair of Cisco Nexus 9k switches configured for vPC and recently one of my switches developed a fault which resulted in the working switch suspending all the vPC ports. Further investigation revealed the layer 3 vlan that had the IP addresses for the vpc keep-alive was down, which wasn't expected. To get the interface back I had to remove the 'vpc peer-link' from my port-channel and put it back.
Below is the config relating to my vPC - i've not included the entire config
Swicth01
feature lacp
feature vpc
vlan 901
name keepalive
vrf context management
vpc domain 1
role priority 900
peer-keepalive destination 10.70.108.13 source 10.70.108.12 vrf default
auto-recovery
interface Vlan8
no shutdown
management
ip address 10.70.108.12/24
interface port-channel10
switchport
switchport mode trunk
switchport trunk allowed vlan 1-5,8,10-12,201-202,300
spanning-tree port type network
vpc peer-link
interface Ethernet1/49
description *** VPC PEER LINKS ***
switchport
channel-group 10 mode active
no shutdown
interface Ethernet1/50
switchport
no shutdown
interface mgmt0
vrf member management
Switch02 - this one developed the fault
feature lacp
feature vpc
vlan 901
name keepalive
vpc domain 1
role priority 10000
peer-keepalive destination 10.70.108.12 source 10.70.108.13 vrf default
auto-recovery
interface Vlan8
no shutdown
management
ip address 10.70.108.13/24
switchport
vpc peer-link
switchport
no shutdown
switchport
no shutdown
interface mgmt0
shutdown force
I am not using the management interfaces - they are not plugged in.
My questions:
1. Does the config look correct
2. Should I expect to see this behaviour if either switch fails
Any help would be greatly appreciated
JB
Reza Sharifi
auto-recovery
interface Vlan8
no shutdown
management
The Keep-alive interface needs to be a physical interface and not a vlan.
 Most of the time mgmt0 interface is used for the keep-alive.
See page-28 in this document:
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Reza Sharifi
auto-recovery
interface Vlan8
no shutdown
management
toprock1970
Thank you for your help.
JB
