Bookmark
Subscribe
662
Nexus and FTD
bilal.atif
  • We need a layer-3 redundancy between Firepower (2100) and Nexus 7K switches
  • Switches and firepower IP schemes are mentioned.
  • Both Firepower ( F2100) are running in HA mode separately.
M02@rt37
Hello @agha talha,
Using Cisco Nexus switches and looking for a high-availability solution that provides L3 redundancy between Firepower and Nexus 7000 switches, you can consider using Virtual Port Channels (vPC). vPC allows you to create a loop-free topology while providing redundancy and load balancing.
Best regards
