Nexus N3K-C3524P-10GX won't boot after power outage.
mmedcalf
Our Nexus won't boot after a power outage.  Could not console in (no response) so I rebooted while connected and got what's appearing in this screenshot:
Every support doc I've found involves having some level of console control, whether it be to gather logs or try to reflash.  Any thoughts on the issue?  Any thoughts on a resolution?
Thank you!
Ruben Cocheno
@mmedcalf
Check if the console cable is loose and/or console settings are correct, otherwise i would  probably reflash it.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
That kind of output from the console usually indicates a mismatch in speed of your console connection and the console port. I suggest that first you check the settings of your computer and its connection to the console. It that seems correct I would suggest that you test using console speeds from as slow as 2400 to as fast as 115200
Rick
