Nexus N9k. System Message logging configuration
alex2024
We would like to see a message in syslog from users logged in via SSH or Console. Who and when was logged in to N9K switch.
Which parameters must then be configured?
The messages come to the syslog server. But either too much or too little. Which logging severity level is better to change
What else would be useful for the syslog configuration?
marce1000
   - FYI : https://community.cisco.com/t5/network-management/log-configuration-changes-to-syslog-on-nexus-7000/m-p/2509023#M102073
 M.
alex2024
Thank you. I have the following syslog configuration
switch(config)#logging level aaa 6
switch(config)#logging level acllog 6
switch(config)#logging logfile LOGs 6
switch(config)#logging server x.x.x.x port 1234 use-vrf management
switch(config)#logging source-interface mgmt0
switch(config)#logging origin-id hostname
I see syslog messages, but not users logged via ssh or console. This is possible with old Cat IOS switches. Is it also possible with nexus?
 - No , nx-os is different check instructions from https://community.cisco.com/t5/network-management/log-configuration-changes-to-syslog-on-nexus-7000/m-p/2509023#M102073
 M.
