Nexus Switches Config Backup Help
kannan.kannan
Hi Team,
I have a small doubt with Nexus 7k,5K,2k & 1K
We want to backup the running config to my desktop through tftp.
When i tried to backup from Nexus switches showing like below
Nexus 7K
copy running-config startup-config ? ===== Can i use this one or
  <CR>
  vdc-all  Perform copy for all vdcs ======= What is the usage of this Vdc-all
It's showing two choices which one I have to follow "copy running-config startup-config" or "copy running-config startup-config Vdc-all"
Nexus 5K
  <CR>
  fabric  Copy from source to fabric startup configuration
It's showing two choices which one I have to follow "copy running-config startup-config" or "copy running-config startup-config fabric"
Nexus 1K
  <CR>
It's showing three choices which one I have to follow "copy running-config startup-config" or "copy running-config startup-config fabric" or "copy running-config startup-config vdc-all"
Which one is having whole config.
Thanks..
Kannan
Hi Kannan,
To copy the running configuration for all virtual device contexts (VDCs) to the startup configuration, use the show copy running-config startup-config vdc-all command.
Inayath.
11 Replies 11
InayathUlla Sharieff
HI kannan,
Please find details below:
Nexus 7K
Nexus7010# copy running-config tftp:192.168.1.1
Enter vrf (If no input, current vrf 'default' is considered):
Enter hostname for the tftp server:
Trying to connect to tftp server......
Could not connect to tftp server:No route to host
You must save the resource allocation from the default VDC before you can save the configuration in a nondefault VDC. Log into the default VDC and use the
command to save the resource allocation. Log into the nondefault VDC and save the configuration or use the
vdc-all
command in the default VDC to save the configuration in all VDCs
Ref:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/virtual_device_context/configuration/guide/vdc_mgmt.html#wp1186733
Nexus 5K
My question is you said that you want to copy the config on TFTP then why are you copying the config to startup?
Inayath
        *Plz rate all usefull posts.
Hi Inayath,
My Simple question, I want to backup the whole config from Nexus switches.
Shall use the below command.
copy running-config tftp://xx.xx.xx.xx vrf
this command it will take whole config backup is it?
Incase down in future we can use this back up to reload that's the reason I am asking.
Thanks....
Kannan
Commit any changes to your start-up config I.e.
Copy run start
And then copy startup tftp:........vrf ....
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thanks Bilal,
When I copy , it's showing two option which one i have to choose for whole config backup
"copy running-config startup-config" (or) "copy running-config startup-config vdc-all "
Please advise
You must save the resource allocation from the default VDC before you can save the configuration in a nondefault VDC. Log into the default VDC and use the copy running-config startup-config command to save the resource allocation. Log into the nondefault VDC and save the configuration or use the copy running-config startup-config vdc-all command in the default VDC to save the configuration in all VDCs.
Then as mentioned you can copy for all VDCs to tftp
Nexus7010# copy run start vdc-all
Nexus7010# copy start tftp:1.1.1.1 vdc-all
Hi Kannan,
Nexus7010# copy running-config tftp:1.1.1.1 vdc-all
Copies the running configuration for all the VDCs with vrf default else you can configure the vrf name of which you want to take the backup.
Inayath
Please advise
Hi Kannan,
Inayath.
I would like to know about nexus 5K & 1k also.
Can you please explain?
Cisco NX-OS             can segment operating system and hardware resources into virtual device             contexts (VDC) that emulate virtual devices. The              Cisco Nexus 5000 Series             switch does not support multiple VDCs. All switch resources are managed in the             default VDC.
So you would use the normal like this:
Nexus5K# copy startup-config tftp:x.x.x.x
I don't know if the Nexus1KV supports VDC's but you could try these:
Nexus1KV# copy startup-config tftp:x.x.x.x
or
Nexus1KV# copy startup-config tftp:x.x.x.x vdc-all
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
HI Kannan,
I dont have Nexux 1K box as of now but looking at the config guide the cmd is same.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0/interface/configuration/guide/if_5portchannel.html
Inayath
