nexus vpc is down
R Manjunatha
Level 3
Level 3
I confirmed VPC in two Nexus switches and PVC peer-Link is down.
Is there any issue with the configuration.
sw-secondary
vrf context management
vpc domain 10
role priority 10
peer-keepalive destination 192.168.1.1 source 192.168.1.2
interface port-channel15
description ** vpc peer-link**
switchport mode trunk
vpc peer-link
interface Ethernet1/1
channel-group 15 mode active
interface Ethernet1/2
interface mgmt0
vrf member management
ip address 192.168.1.2/30
line console
line vty
sw-secondary(config-if)# sh vpc b
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 10
Peer status : peer link is down
vPC keep-alive status : peer is alive
Configuration consistency status : failed
Per-vlan consistency status : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : none established
Number of vPCs configured : 0
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po15 down -
sw-secondary(config)# sh vpc statistics peer-link
port-channel15 is down (No operational members)
admin state is up,
Hardware: Port-Channel, address: 505e.d802.8408 (bia 505e.d802.8408)
Description: ** vpc peer-link**
MTU 9216 bytes, BW 100000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
auto-duplex, 1000 Mb/s
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth1/1, Eth1/2
0 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 0 bits/sec, 0 packets/sec
300 seconds output rate 0 bits/sec, 0 packets/sec
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
sw-primary
vpc domain 10
role priority 20
peer-keepalive destination 192.168.1.2 source 192.168.1.1
description **vpc peer-link**
vpc peer-link
interface mgmt0
ip address 192.168.1.1/30
line console
line vty
2 Accepted Solutions
you need to make peer-keepalive vrf aware
peer-keepalive destination 192.168.1.2 source 192.168.1.1 vrf  management
Reza Sharifi
Are physcical ports e1/1 and e1/2 up? If they are down, you may want to add the proper speed command to all and see if the ports come up.
speed xxx
Also, the vpc peer-link PO should have
spanning-tree port type network
Reza Sharifi
speed xxx
