Nexus9318yc-xc
ja.aljaloud
Hallo,
i had a Problem with Nexus Switch 93180YC-EX, after I updated to version 9.3.8 ( it had NX-OS Release 7.0(3)I7(3) ) and everything is going ok without the ospf.
The ospf neighbours on outside interface to ISP is down, the switch can’t build more the relationship between the outside interface e1/0/7 and the ISP.
We have one link physical ( int e1/7 ) to service provider and vpn tunnel on the interface vlan 2 (SVI).
with VPN the switch can build the ospf neighbours with isp per int VLAN 2, and now we could communicate with other side, here we don not have problems.
But the interface e1/7 which connect directly to isp ( MPLS ) can’t see more the neighbours and can not build the ospf with other side, even we did not change anything in the configuration.
Note : i did the upgrade in this path : 7.0(3)I7(3) → 7.0(3)I7(10) → 9.3(8)
is this problem because of the upgrade?
thanks in advance
7 Replies 7
Reza Sharifi
When you say "outside interface to ISP is down, the switch can’t build more the relationship between the outside interface e1/0/7 and the ISP" Do you mean the physical interface is down or the OSPF neighborship? Can you post the config for interface 1/0/7? Can you also post the OSPF config?
Hallo,
show run interface eth1/7
interface Ethernet1/7
description Uplink_Medac
no switchport
ip address 10.205.1.254/24
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 151F081B012E2E2868
ip ospf cost 10
no ip ospf passive-interface
no shutdown
ONCNX001# show interface ethernet 1/7
Ethernet1/7 is up
admin state is up, Dedicated Interface
Hardware: 100/1000/10000/25000 Ethernet, address: 00be.75db.17bb (bia 00be.75db.17c2)
Description: Uplink_Medac
Internet Address is 10.205.1.254/24
MTU 1500 bytes, BW 1000000 Kbit , DLY 10 usec
Encapsulation ARPA, medium is broadcast
full-duplex, 1000 Mb/s, media type is 1G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is off
Last link flapped 04:46:02
2 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 688 bits/sec, 0 packets/sec
30 seconds output rate 72 bits/sec, 0 packets/sec
input rate 688 bps, 0 pps; output rate 72 bps, 0 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 40 bits/sec, 0 packets/sec
300 seconds output rate 112 bits/sec, 0 packets/sec
input rate 40 bps, 0 pps; output rate 112 bps, 0 pps
RX
8083 unicast packets 2871 multicast packets 0 broadcast packets
10954 input packets 1390154 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
391 unicast packets 953 multicast packets 6 broadcast packets
1350 output packets 289454 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
ONCNX001#
ONCNX001# show ip ospf inter
interface internal
ONCNX001# show ip ospf interface brief
OSPF Process ID 1 VRF default
Total number of interface: 12
Interface ID Area Cost State Neighbors Status
Vlan350 8 51.0.0.0 40 DR 0 up
Vlan344 7 51.0.0.0 40 DR 0 up
Vlan343 6 51.0.0.0 40 DR 0 up
Vlan226 12 51.0.0.0 40 DR 0 up
Vlan224 11 51.0.0.0 40 DR 0 up
Vlan218 10 51.0.0.0 40 DR 0 up
Vlan216 9 51.0.0.0 40 DR 0 up
Vlan14 5 51.0.0.0 40 DR 0 up
Vlan12 4 51.0.0.0 40 DR 0 up
Vlan11 3 51.0.0.0 40 DR 0 up
Vlan10 2 51.0.0.0 40 DR 0 up
Vlan2 1 51.0.0.0 40 BDR 1 up
no switchport
ip ospf cost 10
no shutdown
ONCNX001#
the port is up but the problem now i see these logging :
sh logging | in 1/7
ONCNX001# sh logging | in 1/7
2022 Jan 19 14:42:44 ONCNX001 %ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/7 is down (Transceiver Absent)
2022 Jan 19 14:42:59 ONCNX001 %ETHPORT-5-IF_HARDWARE: Interface Ethernet1/7, hardware type changed to 1G
2022 Jan 19 14:43:05 ONCNX001 %CDP-5-NEIGHBOR_ADDED: Device RG_UG-11-sw01.medac.de discovered of type cisco WS-C4510R-E with port GigabitEthernet10/1 on incoming port Ethernet1/7 wit
h ip addr 10.205.1.1 and mgmt ip 10.205.1.1
2022 Jan 19 14:43:05 ONCNX001 %ETHPORT-5-SPEED: Interface Ethernet1/7, operational speed changed to 1 Gbps
2022 Jan 19 14:43:05 ONCNX001 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/7, operational duplex mode changed to Full
2022 Jan 19 14:43:05 ONCNX001 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/7, operational Receive Flow Control state changed to off
2022 Jan 19 14:43:05 ONCNX001 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/7, operational Transmit Flow Control state changed to off
2022 Jan 19 14:43:05 ONCNX001 %ETHPORT-5-IF_UP: Interface Ethernet1/7 is up in Layer3
2022 Jan 19 14:43:23 ONCNX001 %LLDP-5-SERVER_ADDED: Server with Chassis ID c47d.4f73.edbf Port ID Gi10/1 management address 10.205.1.1 discovered on local port Eth1/7 in vlan 0 with
enabled capability Bridge Router
2022 Jan 19 15:05:00 ONCNX001 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/7 is down(Config change)
2022 Jan 19 15:05:00 ONCNX001 %CDP-5-NEIGHBOR_REMOVED: CDP Neighbor RG_UG-11-sw01.medac.de on port Ethernet1/7 has been removed
2022 Jan 19 15:05:00 ONCNX001 %LLDP-5-SERVER_REMOVED: Server with Chassis ID c47d.4f73.edbf Port ID Gi10/1 on local port Eth1/7 has been removed
2022 Jan 19 15:05:01 ONCNX001 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet1/7 is down (Administratively down)
2022 Jan 19 15:05:03 ONCNX001 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet1/7 is admin up .
2022 Jan 19 15:05:08 ONCNX001 %ETHPORT-5-SPEED: Interface Ethernet1/7, operational speed changed to 1 Gbps
2022 Jan 19 15:05:08 ONCNX001 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/7, operational duplex mode changed to Full
2022 Jan 19 15:05:08 ONCNX001 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/7, operational Receive Flow Control state changed to off
2022 Jan 19 15:05:08 ONCNX001 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/7, operational Transmit Flow Control state changed to off
2022 Jan 19 15:05:08 ONCNX001 %ETHPORT-5-IF_UP: Interface Ethernet1/7 is up in Layer3
2022 Jan 19 15:05:16 ONCNX001 %LLDP-5-SERVER_ADDED: Server with Chassis ID c47d.4f73.edbf Port ID Gi10/1 management address 10.205.1.1 discovered on local port Eth1/7 in vlan 0 with
2022 Jan 19 15:06:05 ONCNX001 %CDP-5-NEIGHBOR_ADDED: Device RG_UG-11-sw01.medac.de discovered of type cisco WS-C4510R-E with port GigabitEthernet10/1 on incoming port Ethernet1/7 wit
2022 Jan 19 22:07:38 ONCNX001 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/7 is down(Config change)
2022 Jan 19 22:07:38 ONCNX001 %LLDP-5-SERVER_REMOVED: Server with Chassis ID c47d.4f73.edbf Port ID Gi10/1 on local port Eth1/7 has been removed
2022 Jan 19 22:07:38 ONCNX001 %CDP-5-NEIGHBOR_REMOVED: CDP Neighbor RG_UG-11-sw01.medac.de on port Ethernet1/7 has been removed
2022 Jan 19 22:07:38 ONCNX001 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet1/7 is down (Administratively down)
2022 Jan 19 22:07:40 ONCNX001 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet1/7 is admin up .
2022 Jan 19 22:07:45 ONCNX001 %ETHPORT-5-SPEED: Interface Ethernet1/7, operational speed changed to 1 Gbps
2022 Jan 19 22:07:45 ONCNX001 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/7, operational duplex mode changed to Full
2022 Jan 19 22:07:45 ONCNX001 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/7, operational Receive Flow Control state changed to off
2022 Jan 19 22:07:45 ONCNX001 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/7, operational Transmit Flow Control state changed to off
2022 Jan 19 22:07:45 ONCNX001 %ETHPORT-5-IF_UP: Interface Ethernet1/7 is up in Layer3
2022 Jan 19 22:07:47 ONCNX001 %LLDP-5-SERVER_ADDED: Server with Chassis ID c47d.4f73.edbf Port ID Gi10/1 management address 10.205.1.1 discovered on local port Eth1/7 in vlan 0 with
2022 Jan 19 22:08:09 ONCNX001 %CDP-5-NEIGHBOR_ADDED: Device RG_UG-11-sw01.medac.de discovered of type cisco WS-C4510R-E with port GigabitEthernet10/1 on incoming port Ethernet1/7 wit
ONCNX001#
Interface 1/7 seems to be bouncing. Can you hard set the interface to 1Gig and test again?
no switchport
speed 1000
no negotiate auto
ip ospf cost 10
no shutdown
i ´did but i still have the issue and logging.
here ist the output of tranciever : e1/7 :
ONCNX001# sh int e1/7 transceiver
Ethernet1/7
transceiver is present
type is 1000base-T
name is CISCO
part number is SP7041-TE
revision is A1
serial number is MTC21470P8X
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is 3
cisco extended id number is 4
cisco part number is 30-1475-01
cisco product id is GLC-TE
cisco version id is V01
ONCNX001# sh int e1/7 | in media
ONCNX001#
Do you think is the problem with SFP ?!
It could be especially since this is a GLC-TE.
I would replace the cable first, and then if that does not help, replace the GLC-TE
According to the Matrix, GLC-TE is supported in this platform. See link:
https://tmgmatrix.cisco.com/?npid=43
Thanks, i will do that tomm, and i will let you know.
Hey, does not work today, do you have another idee?!
