nme-xd-48es-2s-p module has no interface in the CLI
clacsa001
hi good day i have a cisco 3825 integrated service router and it has "c3825-ipbasek9-mz.124-24.T3.bin". I need help it says in the show diag i have slot 2 as nme-xd-48es-2s-p, But i can't see it on the CLI or in show ip interface brief thank you in advance
Richard Burts
You use the connect command to access the service module and then to configure it. See this link for details about how to configure this Service Module
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t2/serdescn.html#wp1066995
Rick
Rick
Rick
Thank you i will try it and post again if it doesn't work
clacsa001
Hello i have access the module using service-module gigabitEthernet 2/0 session but im stuck on
switch:
and i also got an error
switch: usb 3-1: device descriptor read/all, error 12
i was following this guide
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/network-modules/82288-es-mod-config.html#step1
