no bootflash:
accu-cisco
So, I don't have an image on my bootflash: and I don't see a way to get it on there. Here's the output from hyperterminal.
System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMENT SOFTWARE
Copyright (c) 1994-2000 by cisco Systems, Inc.
C7200 platform with 524288 Kbytes of main memory
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "cisco2-C7200"
string is disk0:c7200-adventerprisek9-mz.124-15.T1.bin
loadprog: error - on load of image from file system with monlib
boot: cannot load "disk0:"
boot: cannot determine first file name on device "bootflash:"
rommon 1 > dir bootflash:
File size Checksum File name
rommon 2 > dir slot0:
Directory of slot0:
2 41001236 -rw- c7200-adventerprisek9-mz.124-15.T1.bin
rommon 3 > boot slot0:c7200-adventerprisek9-mz.124-15.T1.bin
boot: cannot load "disk0:c7200-adventerprisek9-mz.124-15.T1.bin"
rommon 4 > help
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cpu_card_type display CPU card type
dev list the device table
dir list files in file system
dis disassemble instruction stream
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set show all monitor variables
show_spd show all SPD data
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
rommon 5 >
I am really up a creek on this one. Please help!!!
Mark Yeates
Level 7
Level 7
Is this a new CF/PCMCIA card that you are using? If you have another router try to format the card through the router, and re copy the IOS back on to the card. You might want to try downloading a boot helper image to get you out of rommon. What processor are you using in the 7200?
Mark
No, it's not new. I have been using it for a while now. What happened is that I did a 'format bootflash:'. But the image that I have always been using is still on slot0:. I don't understand why all of the sudden I can't boot off of the image I always have when the bootflash: helper image is gone. How do you suggest downloading the boot helper image and putting it in bootflash:? I don't have any tftp commands in rommon mode.
Do you have another card that you can use? You will need the card to get the router out of rommon to be able to copy files to bootflash. If this is not an option Xmodem will be able to transfer either the helper or the IOS to bootflash.
No, I don't have another card. This is the same card that was working fine before I did 'format bootflash:'. The IOS image (c7200-adventerprisek9-mz.124-15.T1.bin) located on slot0: was booting perfectly before I issued that command. I don't have any xmodem commands in rommon mode so that is out of the question.
