No connected route for VLAN interface
stephen.laroche
I'm trying to add new VLANs to my Cisco 3750, but am having problems. I can add the vlan int and associate an IP with it, but I cannot ping the vlan interface, nor does it show up as a connected route when I do a show ip route. Here's the info below:
Building configuration...
Current configuration : 5515 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Switch
enable secret
no aaa new-model
switch 1 provision ws-c3750-48ts
ip subnet-zero
ip routing
ip dhcp excluded-address 192.168.2.1 192.168.2.50
ip dhcp excluded-address 192.168.2.101 192.168.2.254
ip dhcp pool VLAN2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback1
ip address 192.168.253.2 255.255.255.255
interface FastEthernet1/0/1
switchport access vlan 2
spanning-tree portfast
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.2.1 255.255.255.0
interface Vlan3
ip address 10.57.200.1 255.255.255.0
interface Vlan4
ip address 10.56.2.1 255.255.255.0
interface Vlan5
ip address 10.56.12.1 255.255.255.0
interface Vlan6
ip address 10.56.22.1 255.255.255.0
router eigrp 100
network 192.168.2.0
network 192.168.253.2 0.0.0.0
network 192.168.254.0
auto-summary
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password xxx
login
line vty 5 15
password xxx
login
end
Switch#ping 10.57.200.1
Sending 5, 100-byte ICMP Echos to 10.57.200.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch#
Switch#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.254.0/24 is directly connected, FastEthernet1/0/46
D 192.168.1.0/24 [90/28416] via 192.168.254.2, 00:04:11, FastEthernet1/0/46
192.168.253.0/24 is variably subnetted, 2 subnets, 2 masks
D 192.168.253.0/24 is a summary, 00:04:11, Null0
C 192.168.253.2/32 is directly connected, Loopback1
C 192.168.2.0/24 is directly connected, Vlan2
Switch#
7 Replies 7
The route would only show up if the VLAN 3 interface is up. You need to have atleast one active port on vlan 3 or a trunk port in which 3 VLAN is active for the interface to come up. Can you assign one of the active ports to vlan 3 and check the status?
Sundar
That worked for vlan3 int. I've got another Netgear smart switch that needs to see these vlans as well. I've got fa1/0/47 set up like this:
interface FastEthernet1/0/47
switchport mode dynamic desirable
Will that serve as an appropriate trunk to allow the vlans be seen across both switches? Essentially a trunking interface...
Steve
Try this configuration.
int f1/0/47
switchport mode trunk
Sundar
The Netgear switch has an IP of 192.168.2.3 which is on Vlan2. After setting the trunk encaps. and the mode, I cannot ping the netgear switch.
Did you create vlan 2 itself and not the vlan interface in the Netgear?
That was it...I had not created the trunking port on the netgear switch. I can ping it now. Thanks for your help!
frosalia
stephen,
perform a 'show interface' command. My guess is the vlans you have created are down, since there is no port(s) assigned to the new vlan(s).
