Question about Fallback Bridging
lamav
Level 8
Level 8
Here is the DLSW config from an L3 CatOS swtich Im working on.
bridge 1 protocol ieee
bridge 2 protocol ieee
bridge 3 protocol ieee
bridge 4 protocol ieee
bridge 5 protocol ieee
bridge 6 protocol ieee
bridge 7 protocol ieee
interface Vlan73
description Server VLAN73
ip address 10.0.16.2 255.255.255.0 secondary
ip address 10.27.73.2 255.255.255.0
no ip redirects
no ip unreachables
ipx input-network-filter 902
ipx input-sap-filter 1002
ipx encapsulation SAP
ipx network A1B4900
ipx output-gns-filter 1050
standby 16 ip 10.0.16.1
standby 16 timers 5 15
standby 16 priority 175
standby 16 preempt
standby 73 ip 10.27.73.1
standby 73 timers 5 15
standby 73 priority 175
standby 73 preempt
bridge-group 1
bridge-group 1 input-address-list 702
dlsw local-peer peer-id 10.27.13.1
dlsw remote-peer 0 tcp 10.27.2.1
dlsw remote-peer 0 tcp 10.27.1.1
dlsw bridge-group 1
dlsw bridge-group 2
dlsw bridge-group 3
dlsw bridge-group 4
dlsw bridge-group 5
dlsw bridge-group 6
dlsw bridge-group 7
Its very straightforward. Nothing weird about it, except that this is the only interface in this bridge group. There are also 2 other SVIs that are put into 2 different bridge groups, too. So, what we have are 3 SVIs with each of them being placed in 3 different bridge groups.
Thats what is confusing me. Whats the point of only putting one vlan in a bridge group? i thought the point of the group is to be able to bridge (pass) traffic between machines on different network segments that are running non-routable protocols, like SNA, etc.
In other words, I would expect to see 2, 3 or more SVIs being placed in the same bridge group so that devices on each of those vlan can pass traffic between each other.
what am I missing?
lamav
Level 8
Level 8
Check out the attachment and read this associated paragrpah to understand what I am asking. Thank you.
Figure 42-1 shows a fallback bridging network example. The switch has two ports configured as SVIs with different assigned IP addresses and attached to two different VLANs. Another port is configured as a routed port with its own IP address. If all three of these ports are assigned to the same bridge group, non-IP protocol frames can be forwarded among the end stations connected to the switch even though they are on different networks and in different VLANs. IP addresses do not need to be assigned to routed ports or SVIs for fallback bridging to work.
