12-31-2024 01:11 PM
I just received 2 brand new C9200CX switches to put to use at my business. Unlike the other switches I have on property this one has the micro USB port for the serial connection. I have downloaded and installed the USB driver from Cisco. I am unable to connect to either of the two switches. My computer only sees these switches as unknown USB devices. I have tried all of the baud rate setting with PUTTY with no luck. I have tried using Tera Term to connect also with no luck. My computer does not see the connection as a com port connection with either of these two switches. I have unloaded the USB console driver several time still with no luck. I also went as far as to buy a USB cable labeled and sold as a console cable with no luck. I would really like to learn what exactly it is that I am missing. Also just to share, some of my other Cisco switches do have a micro USB console port on them besides the RJ45 console port. I plugged my USB cable into one of those switches and it connects with no issues meaning my problem is directly related to the 9200X switches I have now. If I can not access these switches and program them in a fashion that will work with my network they are useless to me and I will be forced to spend a lot of money to buy switches something that I will not truly use all of its capabilities.
12-31-2024 01:38 PM
I am not sure about this model but 9200 offers the possibility of setup via gui
Step 4
Launch a web browser on the PC and enter the device IP address (https://192.168.1.1) in the address bar.
Step 5
Enter the Day 0 username webui and password serial number. Note that the serial number is case sensitive.
12-31-2024 02:22 PM
This did not work. I was not able to connect to that IP address.
12-31-2024 01:43 PM
So I did find this and it may need the silicon labs driver vs the cisco driver.
Seems they expect windows to find it?
Step 1 |
Connect a USB cable to the PC USB port. Connect the other end of the cable to the switch mini-B (5-pin-connector) USB console port. |
Step 2 |
Launch the Windows Update page by clicking on the Update & Security button on the Windows Settings. |
Step 3 |
Click View optional updates. |
Step 4 |
Expand Driver updates and select Silicon Laboratories Inc. – Ports 10.x.x.x. |
Step 5 |
Click Download and install button. Once the driver installation is complete, disconnect the USB cable from the PC USB port and the switch.
12-31-2024 02:23 PM
This driver did not solve my issue. Still no connection from either of the two switches I have at my workstation.
04-24-2025 02:14 PM - edited 04-24-2025 02:15 PM
The problem is, sometimes the cables you find are for "charging only" i.e. they are missing the required pins needed for data transfer. I bought this Cisco blue one from Amazon and has worked fine. https://www.amazon.com/Aexus-Console-Micro-B-Meters-CAB-USB-UB/dp/B0CTGMN329/
12-31-2024 04:32 PM
Try to keep it simple: Use a generic USB Type A to USB Micro-B
I use, for instance, Baseus Cafule Cable USB For Micro 2A on any Windows 10/11 laptop without any problem (no need to download any drivers).
01-02-2025 12:53 PM
generic cable does not work either. I have ordered a DB9 to usb cable to try using with my console connector as it shows a port connection simply by plugging it into my computer, I this console adapter for all of my other network switches.
I will share if it works after I receive and give it a try.
02-26-2025 01:26 PM
Hi ,
I am facing this problem too. Did you have some workaround for this case ?
11-26-2025 09:03 AM
I know this is super late but I found this post cause I had the same problems also trying to access my 9200CX switches.
I'm using a MAC. I had ordered specifically a USB-A to Micro USB Console cable, similar to the ones i've used in the past. It did not work and all I get is a blank screen and I know the cable works cause I'm able to connect it to other devices like HP Aruba AP's and etc.
I found later through searching that the 9200CX's have a built in UART chip on the console port. So what you need is not a CONSOLE cable but just a regular USB Data cable. I used an old playstation controller cable and once plugged into my MAC, I saw the following TTY devices show up: tty.usbserial-210%
