No cookie option for deny acl?
lonelyadmin
This is on a 4500X running 03.08.06.E
There doesn't seem to be a cookie option under the deny statements in an extended ip access-list.
ip access-list extended FOO
switch01(config-ext-nacl)#permit ip any object-group BLOCKED log ?
  WORD        User defined cookie (max of 64 char)
  dscp        Match packets with given dscp value
  fragments   Check non-initial fragments
  option      Match packets with given IP Options value
  precedence  Match packets with given precedence value
  reflect     Create reflexive access list entry
  time-range  Specify a time-range
  tos         Match packets with given TOS value
  <cr>
switch01(config-ext-nacl)#deny ip any object-group BLOCKED log ?
  <cr>
No "WORD" option shown.
Is this intentional or some sort of bug?
Thanks, I saw those before I posted. They don't really say if it should be there on the deny or not. Not mentioned in 4500X docs either.
I opened a case with TAC too. I'll update here.
BrianSekleckiGE
Is this absence of "User defined cookie" a global feature missing from IOS-XE ?
If not defined in documentation, likely a feature not supported.
