no dhcp on Switches 2960
pcfreak49
I have a problem with not getting dhcp ip address, I have tried everything but no results?
12 Replies 12
Leo Laohoo
Are you using the 2960 as a DHCP server?
If you are, can you post the config of the entire switch?
yes this is the running-config IS, I do not know what I did but I get no ip address
Can you remove the "IP DHCP snooping" commands and try again?
yes
I
did that
but I get
no
ip
address
This is
the
current
running-config
Your clients get no IP  from DHCP?
first can you add in global config mode: ip dhcp excluded-address 10.10.10.1
Then try again and if it doesn't work then post output of following commands:
- sh ip int br | in Vlan
-sh run | i ip routing
-sh ip dhcp pool
-sh ip dhcp binding
-sh ip int Vlan1
Regards.
Alain.
the required output of various commands `s
-sh ip int br | in Vlan
-sh run | i ip routing does not work
-sh ip dhcp-pool
-sh ip dhcp binding
-sh ip int Vlan1
Jigar Dave
Level 3
Level 3
after seeing your config, below are my points, your config is
ip dhcp pool LAN
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   lease 0 2
my suggestion is
conf t
no ip dhcp pool LAN
ip dhcp pool LAN_PCFREAK
domain-name pcfreak.com
dns-server *.*.*.* (your DNS server IP)
lease 7
interface vlan 1
ip add 10.10.10.1 255.255.255.0
no ip route-cache
ip tcp adjust-mss 1460
ip dhcp snooping
ip dhcp-server 10.10.10.1
you can try this.
Best regards,
Jigar
Please rate helpful posts.
okay that works but now I can not connect to the Internet
Appreciate if you share your connectivity diagram, without knowing it, perhaps what solution provided to you can go into your network-down condition, we dont want to take that risk.
Jigar
it is the intention that I have Internet on the switches, the otherwise
From your previous config. of SW1, it seems that you dont have default route to next device connected to ( either router or other L3 Switch - from where you connects with internet)
pls add
ip route 0.0.0.0 0.0.0.0 x.x.x.x ( where x.x.x.x is next device connecting interface)
this should work.
- JD
I have seen that the command does not exist on the switches
