“no ip dhcp excluded-address” not removing entry
juddcharles
hello,
I am a small home office user. Recently moved config from an old Cisco 1900 to a newer Cisco 1100 series.
I am unable to remove a excluded DHCP scope statement.  From the cli "no ip dhcp excluded-address x.x.x.x x.x.x.x" does not remove the entry.  As a result, I only have 25 DHCP addresses to play with, and the next DHCP clients are not being issued DHCP addresses.  Pool is exhausted.
Ios config clearly has a DHCP exclusion scope... I have no idea how it got there but I can't remove it.
How can I remove the excluded-address statement please?
ip host CISCO-CAPWAP-CONTROLLER.local 10.0.2.5
ip host cisco-lwapp-controller.local 10.0.2.5
ip name-server 8.8.8.8 8.8.4.4
no ip domain lookup
ip domain name .local
ip dhcp excluded-address 10.0.1.26 10.0.1.255
I've tried deleting the DHCP pool, then removing the excluded-address entry, and then re-adding the DHCP pool.  Issuing the command under config t does not remove the entry.  A reboot does not remove the entry.  it's like it's locked or read only or something.
no ip dhcp excluded-address 10.0.1.26 10.0.1.255
DHCP Debug log shows
DHCPD: subnet [10.0.1.1,10.0.1.254] in address pool LAN-pool1 is empty.
DHCPD: due to: POOL EXHAUSTED
Router address is 10.0.1.254
DHCP Pool assigned as
ip dhcp pool LAN-pool1
import all
network 10.0.1.0 255.255.255.0
default-router 10.0.1.254
dns-server 10.0.1.254
domain-name .local
option 43 ascii "10.0.2.5"
lease 1
DHCP utilisation shows
Pool LAN-pool1 :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 65534
Leased addresses : 0
Excluded addresses : 245
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased/Excluded/Total
10.0.0.1 10.0.0.1 - 10.0.255.254 0 / 245 / 65534
Clients connect via a catalyst switch via VLAN10 with DHCP helper address pointing to router.
interface Vlan10
ip address 10.0.1.97 255.255.255.0
ip helper-address 10.0.1.254
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip igmp join-group 239.20.226.197
ip igmp version 3
ip cgmp
 installed ios version
System image file is "flash:c1100-universalk9.17.08.01a.SPA.bin"
Cisco IOS XE Software, Version 17.08.01a
I found the problem.
There was this entry in the ios config
app-hosting appid guestshell
app-vnic management guest-interface 0
guest-ipaddress 10.0.1.254 netmask 255.255.255.0
end
I dont use the "app-hosting" capability on the Cisco 1100 router...and it appears to be bad news for DHCP scopes.  Maybe carves out a chunk of address range for it's self?  I dont know.
But as soon as I removed with
C1121X-8PLTEP(config)#no app-hosting appid guestshell
I got my DHCP pool back, and the DHCP exclusion had disappeared.
try and disable the DHCP service first before removing the reservation:
1100(config)#no service dhcp
Thanks Georg,
I tried disabling/removing the DHCP service and then removing the excluded address-statement, and it is still not removed.   It is like it's administratively locked or read only.  I get no message on console or log when trying to remove it.
The process I used described below;
Remove DHCP service
C1121X-8PLTEP(config)#no service dhcp
Remove DHCP pool
C1121X-8PLTEP(config)#no ip dhcp pool LAN-pool1
Save config
C1121X-8PLTEP#write mem
Remove exclude-address scope
C1121X-8PLTEP(config)#no ip dhcp excluded-address 10.0.1.26 10.0.1.255
Save config
show run and the exclude scope is still there
show run
C1121X-8PLTEP#ip dhcp excluded-address 10.0.1.26 10.0.1.255 <<< entry still there
Save and reload the router
C1121X-8PLTEP#copy run start
C1121X-8PLTEP#reload
after reload, the entry is still there
show run
C1121X-8PLTEP#ip dhcp excluded-address 10.0.1.26 10.0.1.255 << entry still there after reload
Try removing the exclude scope again
Save config
show run to see if the exclude scope is still there... and it's still there
show run
very frustrating.
I also tried viewing, then clearing DHCP conflicts.  there was one record in there.
C1121X-8PLTEP#show ip dhcp conflict
IP address Detection method Detection time VRF
10.0.1.6 Ping Feb 10 2023 09:21 AM
C1121X-8PLTEP#clear ip dhcp conflict *
Conflict table is now empty.
end
