Not able to change configuration registry to 0x2102 - returning "usage: confreg"
RobCannon3691
As title explains, I am not able to change the confreg in rommon to 0x2102 by issuing:
rommon 5 >confreg 0x2102
usage: confreg
When I issue confreg, I am trying all sorts of options and am always booting in 0x0101 or 0x0142.
How do I change the configuration registry in this case.  This relates to this issue that I am still struggling with.
Thank you for any help.....
If this is a switch then 0x102 is "right".
What error message did you get when trying to copy an IOS into the switch?
8 Replies 8
Leo Laohoo
try "confreg 2102".
Thank you for the help.
That command returns the same thing.
rommon 10 >confreg 2102
usage: confreg
Env vars still the same.
Is this a router or a switch?
Very sorry, should have mentioned that.
C4948 switch running rom monitor 12.2.
I am trying to get the IOS image on via tftp but am in the wrong configuration right now.
Thank you for the help. I'm a noob with this stuff. All the docs I read told me to change the confreg even though I am really just trying to load the OS which is missing from the bootflash.
I am getting a timeout error when I run
boot tftp://192.168.10.2/cat4500-ipbasek9-mz.150-2.SG11.bin
even though I am able to successfully ping that address.  I started up the tftp server on that host and binded it to the address and put the right image in the TFTP-Root folder.  They are connected via the management port with a straight cable.
 Tftp Session details are ....
 Filename     : /cat4500-ipbasek9-mz.150-2.SG11.bin
 IP Address   : 192.168.10.3
 Loading from TftpServer: 192.168.10.2
 Tftp session failed: maximum retransmission count exceeded
Oddly though I am not able to ping the other way (tftp to switch).  I would use other commands (tftpdnld and xmodem) but they are missing.
All help greatly appreciated.
Thank you for the suggestion.
I was following that before and had no luck but then it occurred to me that I pinging the tftp wasn't enough, I had to open port 69 on the firewall to get it loaded.
Just got it running.  Thank you so much for your time.
