Not able to ping over VRF
Sanjib Pradhan
Dear Friend,
I have created two VRF on R1 i.e R2 and R10. I am able to ping from R1 to R2. But not able to ping From R1 to R4. Please find below configuration On R1.
ip vrf R10
rd 44:44
ip vrf R2
rd 22:22
R1#sh run int f0/0
Building configuration...
Current configuration : 115 bytes
interface FastEthernet0/0
ip vrf forwarding R2
ip address 12.1.1.1 255.255.255.0
duplex auto
speed auto
R1#sh run int f0/1
Current configuration : 116 bytes
interface FastEthernet0/1
ip vrf forwarding R10
duplex auto
speed auto
R1#ping vrf R2 12.1.1.10
Sending 5, 100-byte ICMP Echos to 12.1.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/45/56 ms
R1#ping vrf R10 12.1.1.10
Success rate is 0 percent (0/5)
R2 and R4 are running same IP that is 12.1.1.10........!!!!!!!!!!!!!!!!!!!!!!!!!! PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sanjib
9 Replies 9
Jon Marshall
Sanjib
We need to see the configurations of R1 and R4 and also -
"sh ip route vrf R10 from R1 and R4"
Jon
R1#sh running-config
Current configuration : 1149 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip vrf R10
rd 44:44
ip vrf R2
rd 22:22
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
!ip tcp synwait-time 5
!interface FastEthernet0/0
duplex auto
speed auto
duplex auto
speed auto
interface FastEthernet1/0
ip address 13.1.1.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp run
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1#sh ip route vrf R10
Routing Table: R10
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     12.0.0.0/24 is subnetted, 1 subnets
C       12.1.1.0 is directly connected, FastEthernet0/1
Sanjib
Need to see the same for R4 as well.
Jon
Jon
I have not created VRF on R4 also on R2....I think no require to configure VRF on R4....
Sanjib
Okay but is R4's fa0/1 interface up and does it have the IP of 12.1.1.10 ?
What happens if you try to ping from R4 ?
Jon
Jon
Right...It's F0/1 and IP address is 12.1.1.10.
R4#ping 12.1.1.10
Sanjib
Sorry to state the obvious but are you sure that you have connected the right port and that it is up.
Your configuration should work fine.
Jon
Yeah............I am sure.
Sanjib
Then from what you have posted i can't see why it wouldn't work.
Jon
