not able to reset the password on 2610
cisco steps
I am trying to set up my old lab.. forgot the password. could not recover it.. I have Hp laptop with tera_term when I restart the router , I do BREAK no luck. I do ctrl+ breack,, no go.. any help please .. Thanks
I sometimes forget too. It happens when I switch between tera term and hyperterminal. Tera term does use a different break sequence than hyperterminal.
Good Luck!
Mark
Mark Yeates
Level 7
Level 7
The break sequence for tera term is ALT+B
HTH,
Mark
will try .. Thanks
cool . It works , I guess is the tera-term thing HUH !!!! :-)
Good Luck!
Mark
