Not able to see mac addresses on trunk ports in Nexus 3k
I have tried with show mac address-table. it is showing only access vlan mac addresses. what is the command that I should use to see the mac addresses that are learnt on trunk interfaces in Nexus devices
Can you try pinging the server than issue command?
show mac address-table interface Po11
or
show mac address-table interface eth1/45
To elimainate any issue with the server, is there a way for you to connected a different server to the same ports and test again?
Reza Sharifi
Not familiar with 3ks, but how about "sh ip arp vlan xx"?
The problem is with the trunk ports(L2 ports). show ip arp gives L3 interface details. Here is my problem, I have connected one citrix netscaler to Eth1/45 and Eth1/46 and created port-chanel 11. Now I want to know the mac address what this switch is learing on Eth1/45, Eth1/46 and Po 11. But mac address-table is showing empty for all these interfaces
switch# Show int Po11
port-channel11 is up
  Hardware: Port-Channel, address: a44c.112b.be74 (bia a44c.112b.be74)
  Description: INFRA:TRUNK:citrix:trunk
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/45, Eth1/46
  30 seconds input rate 2048 bits/sec, 256 bytes/sec, 2 packets/sec
  30 seconds output rate 2712 bits/sec, 339 bytes/sec, 2 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 1.93 Kbps, 2 pps; output rate 2.42 Kbps, 2 pps
  RX
    0 unicast packets 1332985 multicast packets 1243 broadcast packets
    1334228 input packets 170700942 bytes
    0 jumbo packets 0 storm suppression packets
    0 giants 3 input error 0 short frame 0 overrun 0 underrun
    0 watchdog 0 if down drop
    0 input with dribble 1248 input discard(includes ACL drops)
    0 Rx pause
  TX
    0 unicast packets 3283039 multicast packets 153 broadcast packets
    3283192 output packets 435263006 bytes
    0 jumbo packets
    0 output errors 0 collision 0 deferred 0 late collision
    0 lost carrier 0 no carrier 0 babble
    0 Tx pause
  1 interface resets
switch#
switch# show run int Po11
!Command: show running-config interface port-channel11
!Time: Fri Jan 4 16:45:52 2013
version 5.0(3)U3(2a)
  description INFRA:TRUNK:citrix:trunk
  switchport mode trunk
  switchport trunk allowed vlan 101-102
  logging event port link-status
switch#
switch# show run int eth1/45
!Command: show running-config interface Ethernet1/45
!Time: Fri Jan 4 16:45:32 2013
  description INFRA:TRUNK:citrix:10/1
  lacp rate fast
  channel-group 11 mode active
switch
switch# show mac address-table interface Po11
switch#
switch# show mac address-table interface eth1/45
switch#
switch# sh ip arp vlan 102
Flags: D - Static Adjacencies attached to down interface
IP ARP Table
Total number of entries: 0
Address Age MAC Address Interface
switch#
switch#
or
Thanks. I knew but didn't strike in my mind.
