Not asking for enable password
chiragvyas_50
Hi,,,
I have 1800 cisco router. i have already set enable secret password for the router but while i access the router. it doesnt ask me for enable password and directly goes to privileged mode.
It's because of the "privilege level 15" within the VTY configs.
7 Replies 7
Pravin Phadte
Level 5
Level 5
Can you paste the config for the password setting and line vty output.
Pravin
Hi,,,,,
Pravin, Pls find below my config file...
RLI_Veraval#sh run
Building configuration...
Current configuration : 2170 bytes
version 12.4
hostname RLI_Veraval
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
no aaa new-model
resource policy
ip cef
ip domain name yourdomain.com
username cisco privilege 15 secret xxx
interface Loopback0
ip address 97.x.x.171 255.255.255.255
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 10.129.225.193 255.255.255.192
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
encapsulation hdlc
shutdown
interface Serial0/1/0
ip address 97.x.x.181 255.255.255.252
encapsulation ppp
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 97.11.9.182
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege le
vel of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
password cisco
login
line aux 0
line vty 0 4
privilege level 15
password cisco
login
transport input telnet
line vty 5 15
privilege level 15
password cisco
login
scheduler allocate 20000 1000
end
RLI_Veraval#
Joseph W. Doherty
A couple of ways this could be happening, is there a "priviledge 15" within the VTY? Or, are you using AAA with RADIUS or TACACS which is putting the logon into enabled state?
Joseph Is correct.
remove the vty 0 4 privilege level 15 and
line vty 5 15 privilege level 15.
regards,
pravin
Garcias, I saw that in the running config that was (not aaa new-model) just enable
[SW-01 (config) #aaa new-mode] and done.
veevekraj
If you need enable password prompt for vty 0 4(telnet) then config is as below:-
#enable pass cisco
#enable secret cisco1
#username admin pass admin
#username cisco privilege 5 pass cisco
#line vty 0 4
   login local
   privilege  level 15
Telnet will ask for user and password. If you telnet through user admin then it will also ask for enable secret (not enable).
If you telnet with user cisco then it will not ask for enable password. So privilege level command in vty will not affect enable password.
