Not getting IP from dhcp pool cisco 887-VA-K9
stevenr_robins
Hi all.  Can someone look at my config and explain why i am not getting an IP from the router when connected over ethernet cable.  Have tried on 2 different laptops, both just show as unidentified network.  have tried 2 ethernet cables and all 4 ethernet ports on the cisco
TheBeast#sh run
Building configuration...
Current configuration : 2560 bytes
! Last configuration change at 19:33:24 UTC Sat Sep 28 2013
version 15.1
no service pad
hostname TheBeast
boot-start-marker
boot system flash:c880data-universalk9-mz.151-4.M4.bin
boot-end-marker
no logging console
enable secret 4 ##############################
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.0.1 255.255.255.255
ip dhcp excluded-address 192.168.0.12 255.255.255.255
ip dhcp pool HomeNetwork
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 62.24.199.13 62.24.199.23
lease 0 2
ip cef
ip name-server 62.24.199.13
ip name-server 62.24.199.23
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ17119094
vtp mode transparent
controller VDSL 0
firmware filename flash:vdsl.bin-A2pv6C035d_d23j
vlan 10
interface Ethernet0
no ip address
ip virtual-reassembly in
interface Ethernet0.101
encapsulation dot1Q 101
ip address dhcp
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
pvc 0/38
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1432
dialer pool 1
ppp authentication chap callin
ppp chap hostname Bob
ppp chap password 0 bob
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.12 53 interface Dialer0 53
ip nat inside source static udp 192.168.0.12 53 interface Dialer0 53
ip nat inside source static tcp 192.168.0.12 80 interface Dialer0 80
ip nat inside source static udp 192.168.0.12 88 interface Dialer0 88
ip nat inside source static tcp 192.168.0.12 3074 interface Dialer0 3074
ip nat inside source static udp 192.168.0.12 3074 interface Dialer0 3074
ip route 0.0.0.0 0.0.0.0 Ethernet0
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Jonn cos
Level 4
Level 4
Your excluded-address command seems to be a culprit. Instead of defining one single host you are giving it a range from 192.168.0.1 to 255.255.255.255, that is excluding all of the addresses, thats why your client are not getting ips
5 Replies 5
Jonn cos
Level 4
Level 4
Do the following
1) ip dhcp excluded-address 192.168.0.1
    ip dhcp excuded-address 192.168.0.12
and remove "import all" from dhcp pool and then let us know
Jonn cos
Level 4
Level 4
Thanks All.
Doh, how did i miss that.  yes, working fine now.
Thanks for rating..
Jan Hrnko
Level 4
Level 4
Hi Ste,
You have excluded every address in range from 192.168.0.1 to 255.255.255.255
The second address is not mask, it is the high address from range.
Syntax:
Router(config)# ip dhcp excluded-address low-address [high-address]
Best regards,
Jan
