Not Logging all levels of Sylog messages from Core switch 4503
Sihanu N
Hi Experts,
We had a core switch(4503) in our environment and recently we tried to enable syslog in the switch. But the syslog server doesnt receives all the configured level messages from the switch. Following is the only message getting in syslog server after the configuration change in switch.
%SYS-5-CONFIG_I: Configured from console by CWLMS onvty1
(No Traffic related messages like acl deny traffic, spanning tree events etc are getting to syslog server as well as log buffer of the switch)
Following are the logging configuration for the core switch
logging monitor informational
logging facility syslog
logging source-interface Vlan44
logging <syslog server ip>
show logging output
Core#sh logging
Syslog logging: enabled (0 messages dropped, 17 messages rate-limited, 0 flushes
, 0 overruns)
    Console logging: level debugging, 55 messages logged
    Monitor logging: level informational, 0 messages logged
    Buffer logging: level debugging, 72 messages logged
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 47 message lines logged
        Logging to <syslog server ip>, 47 message lines logged
1) Is there any more configurations required for getting all traffic related messages, (i mean all possible messages - upto level 7 - debugging)?
Any advice or suggession regarding the issue is highly appreciable.
Sihanu N
Leo Laohoo
Do you want to see when interfaces go down/up?  By default, this is disabled.  To enable this you need to go to the interface level and enter the command "logging enable link".
For ACL, look at your ACL statements individually.  There should be a "log" option at the end of the line.
Hi Leo,
Many Thanks for reply,
In our environment one server in one of the vlan is configured for syslog server. Please clarify which all interfaces needs to enable the command "logging enable link"?
Sihanu N
Let's say you have interface 2/14 is a server.  You want to see everytime this link goes down/up.  By default, when this link goes down/up you won't see it in the logs.
So if you do this:
conf t
int g 2/14
logging enable link
end
This enables it.
