Not sure what i'm missing. Switch reaching outside network.
cylemmulo1
I'm looking to understand how a certain switch is reaching outside its network.
I've got a switch (2960) in my room office, no ip routing enables, no default-gateway set, no management port. It's assigned let's say 10.0.0.2 /25 on a vlan. That's hooked up to a multiplayer switch to get it out. Now my PC is 10.0.0.200/25. My PC is able to reach it and management, and how is what i'm trying to figure out.
I thought it might be proxy arp, but testing disabling that didn't stop things. It's disabled at the gateway router as well.
One person I talked to said that if it's sitting in the same segment, it would be able to still route out with that multilayer switch. I don't quite understand this though.
Is there something I'm missing? My understanding is that it should just drop that packet when it sees it has no path back, simple as that. Am i be stupid?
5 Replies 5
in theory, 10.0.0.2/25 should not be able to talk to 10.0.0.200 without a layer 3 device. Can you post the configurations of your switch and your router ?
ALL_2960_OFF_23-2#sh run int vlan 2
Building configuration...
Current configuration : 63 bytes
interface Vlan2
ip address 192.17.0.30 255.255.255.224
end
ALL_2960_OFF_23-2#sh run int vlan 3002
Current configuration : 107 bytes
interface Vlan3002
description MGMT
ip address 10.0.0.2 255.255.255.128
no ip proxy-arp
end
ALL_2960_OFF_23-2#ping 10.0.0.200
Sending 5, 100-byte ICMP Echos to 10.0.0.200, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
ALL_2960_OFF_23-2#ping 192.0.42.3
Sending 5, 100-byte ICMP Echos to 192.0.42.3, timeout is 2 seconds:
My router
10.0.0.0/16 is variably subnetted, 11 subnets, 6 masks
C 10.0.0.128/25 is directly connected, Vlan3000
C 10.0.0.0/25 is directly connected, Vlan3002
interface Vlan3000
ip address 10.0.0..214 255.255.255.128
end
ALL_3750_SR3#sh run int vlan 3002
Current configuration : 68 bytes
interface Vlan3002
ip address 10.0.0.96 255.255.255.128
end
Hello
@cylemmulo1 wrote:
My router
interface Vlan3000
end
Can you post the full configuration of the rtr
Kind Regards
Paul
Hi sorry for the delay. So, the full router config I cannot due to security here and what is on it. I meant to grab more but I believe I did figure it out.
It appears to be proxy arp. I didn't think it would propagate that easily, and the reason I didn't see it was because proxy arp doesn't seem to work perfectly. I had to tracert where the traffic was trying to send the traffic to (try to proxy arp from i guess), then create the route there.  Sometimes it wouldn't take the summarized route, and sometimes it wouldn't switch over to the place with redirects configured. But after testing with a new subnet it appears to be it. I'm just not sure how I've never ran into that
Sadly somehow my reply was removed for some reason.
Does this help?
ALL_2960_OFF_23-2#sh ip route Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
Total cdp entries displayed : 1
ALL_2960_OFF_23-2#show ip int brief
Interface IP-Address
Vlan2 192.17.0.30
Vlan3002 10.0.0.2
interface Vlan2
interface Vlan3002
description MGMT
no ip proxy-arp
ALL_2960_OFF_23-2#ping 10.0.0.200 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.0.0.200, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms ALL_2960_OFF_23-2#ping 192.0.42.3 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.0.42.3, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
