NTP Authentication Issue
Not applicable
While I am configuring C7609 route or C6509 switch as ntp server and Cisco 2811 router as ntp client,ntp was not working if the authentication is configured in client side, when removing authentication part from the client ONLY ntp is working, below are attached config:
NTP Server:
HQ-7609#sh run | inc ntp
ntp authentication-key 1 md5 <KEY>
ntp authenticate
ntp trusted-key 1
ntp clock-period 17179881
ntp source Loopback0
ntp master 2
ntp server 10.10.5.2 key 1
NTP Client:
R1#sh run | inc ntp
ntp authenticate
ntp clock-period 17179903
Please advice....
Then it's a really strange config ... Try it the "traditional" way:
Server:
ntp trusted-key 1
ntp master
Client:
ntp authenticate
ntp trusted-key 1
After some waiting (NTP is *really* slow) post the output of "show ntp associations".
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
7 Replies 7
The client also needs "ntp trusted-key 1".
Add the command "ntp trusted-key 1" to the client also the same. my question why the client synchronized with NTP server when I remove the authentication part from the client?
if you remove "ntp authenticate" the client just doesn't care about authentication and always can synchronize with a compatible server.
Ok, but why when authentication exist the client doesn't syncronized with the server ?
What is you actual config? It seems that HQ-7609 is not the NTP-server as that device also synchonizes to IP 10.10.5.2. And how is the NTP-config for that device?
Additionally, if you synchronize to an external source, you don't need "ntp master".
IP 10.10.5.2 is loopback address of C7609 router and at the same time it is a master.
Server:
ntp trusted-key 1
ntp master
Client:
ntp authenticate
ntp trusted-key 1
