NTP questions
NormMuelleman
I've posted NTP questions before, and having NTP issues again.
We are a smaller network, with about 30 switches. The access and distro switches all are configured with
ntp server 192.168.xxx.xxx
So in essence, all switches point to the core switch for NTP time.
Our core has ntp server 10.xxx.xxx.xxx, where it's pointing to our router for NTP. The router is pointed to an authenticated time source.
Also, our core has another entry in the config
ntp source vlan xxx
If I understand this correctly, the core is using the 10.xxx.xxx.xxx as it's time server. But ntp source indicates where the device should get it's time from on which interface. This just seems duplicated....
Now, let's say the core's source is being blocked (ntp got blocked on the firewall). So the core loses it's time, and goes back to the cisco default time.
My follow-up question is this: if I manually set the time on the CORE switch, should it not propagate the time to the distro/access switches, since they are all pointing to it as the ntp server? I've done this, but the access/distro switches aren't picking up the correct time.
I also did a debug ntp sync, debug ntp packets, debug ntp events, etc.....and have never seen any ntp packets or anything pop up.
How often does Cisco IOS do ntp time packets for time synch?
I have IOS 12.2 (53), and have tried to issue ntp master on the core. It won't take the command.
Thoughts and replies are most appreciated
2 Accepted Solutions
Norm,
The 3750 series switches can't be configured as NTP master:
From the config guide:
The switch does not have a hardware-supported  clock and cannot function as an NTP master clock to which peers  synchronize themselves when an external NTP source is not available. The  switch also has no hardware support for a calendar. As a result, the ntp update-calendar and the
ntp master
global configuration commands are not available.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swadmin.html
"NTP Master" can only be used in routers and the 6500, if I remembered correctly.  And I think the 4500 will also support this command.
Honestly, I've had my fair share of "ntp master" issues and I personally won't recommend it.
You have but two options for NTP, and they are:
1.  You need to sync your NTP to a source outside; or
2.  Get a DEDICATED GPS-based NTP server.  Don't get those "lite" NTP server which still has to go outside.
When you stick the command "ntp master" in your router, it tells everyone that the router is a trusted source.  So if your router has 01 March 2001 date and time, guess what?  Your entire network will be based off this time.
8 Replies 8
cadet alain
hi,
For you core switch to provide time sync with ntp you must issue   global config command ntp master on the core switch.
regards.
Alain
Cadet alain:
I have tried that. That's why I stated above. I don't know what's up with the switch not taking the ntp master command. I tried it in global config mode, and it keeps saying unrecognized command. NTP Peer, NTP Server, NTP authentication, etc. all show up. I've used NTP Master before. Our core is a stacked 3750..I dont think that would make a difference, but I've been wrong with that before...
So if I can't use NTP Master, I'm stuck until NTP blockage is corrected at the firewall I guess.
Norm,
ntp master
Reza and Leolahooo..
That's what I needed to know. I thought it had something to do with the 3750 not being allowed to be NTP master..just couldnt find the info and got sidetracked.
Yeah, we ARE pointing to an outside soure..it WAS working until the firewall team blocked NTP again...
Have to re-open NTP for our core switch.
The core points to our router..but again, NTP is blocked
Thanks for all your help! Bottom line, 3750 is useless for NTP Master
Thanks for the ratings.
Get an NTP server with GPS.  They are fairly cheap in the market nowadays.
Don't get the one without any GPS antennas (because they are NOT GPS-based NTP server).
This method is going to be your "redundancy", in case you have issues (again) with something blocking access to S/NTP.
Another thing, some routers have a command "ntp update-calendar".  This is very useful when a router reboots power AND your NTP link is blocked.  The command allows the router to "save" NTP syncs regularly.  So when a router reboots, it'll search for this sync and goes immediately to correct time before NTP could sync.  Very handy.
Hi Leo,
When you say "fairly cheap"  how much are you talking about?
Because I installed a brand new GPS system including Antenna, GPS Server, and Sync Servers, all made by Symmetricom
and that was not cheap.
http://www.symmetricom.com/
Reza
Hi Reza,
A few years ago, we were looking and we saw a 1RU for about AU$900 and in the size of a computer HDD.  Now let me warn you that ANYTHING in Australia is VERY, VERY EXPENSIVE.
We didn't buy it then and we're now re-evaluating this.
Found this though:  http://www.veracityglobal.com/products/networked-video-integration/timenet.aspx
Like the bit that said "PoE".  Hmmmm ...
