NTP Stratum incorrect
jmcgrady1
I have a catalyst 9300 switch running 17.12.04.  When NTP is configured, it can see its two sources. But it incorrectly lists them as being stratum 16. eg;
#sh ntp assoc
address ref clock st when poll reach delay offset disp
~10.70.240.40 .TIME. 16 - 64 0 0.000 0.000 15937.
~192.168.238.79 .TIME. 16 - 64 0 0.000 0.000 15937.
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
Other NTP clients on the network see these sources as Stratum 6 and 1. Why might it be assigning an incorrect stratum and is there way i can override it?
jmcgrady1
This thread gave the solution: Solved: Clock is unsynchronized, stratum 16, no reference clock - Cisco Community
Issue was the switch is communicating through an out of band interface using vrf vrf-mgmt.   I needed to factor that into the ntp config.
jmcgrady1
