NTP
mkannan_29
Hi All,
Can you please help to enable NTP in CISCO router.
Currently ntp has been disabled & I am trying to enable NTP service, but I didn't find the commands.
Currently I have configured ntp clockperiod, ntp peer X.X.X.X & ntp source gig0/0 in my router.
But still I am getting "Clock is unsynchronized, stratum 16, no reference clock".
Below is the config & error message
router#sh run | in ntp
ntp disable
ntp disable
ntp source GigabitEthernet0/1
ntp peer X.X.X.X
router#sh ntp sta
Also if I am scan my network devices I am getting the error message
"Network Time Protocol (NTP) Server Detection An NTP (Network Time Protocol) server is listening on this port".
Need your technical assistance on the above.
M.K
I Hope you are trying to configure the router as NTP client..
First you need to set the timezone after that you need to configure the below commands
ntp server
ntp update-calender
ntp source   // this is the interface in which you should able to reach the NTP server//
For more information,have a look of the below URL
http://www.cisco.com/en/US/docs/ios/12_1/configfun/configuration/guide/fcd303.html#wp1001170
regards
karuppu
Ganesh Hariharan
Hi All,
M.K
Hi M.K,
if you want your router to be NTP server for your local lan then you need to make this as ntp master with startum vlaue and you want you can assign a authentication key also so that trusted clients can sync with your routers.
check out the below link for NTP configuration in routers hope to help
Remember to rate the helpful post
Ganesh.H
Leo Laohoo
Ok.  Firstly, what is your NTP time source?  Is it an authoritative Windows server or something?  NTP clock-period is auto-generated by an appliance once the timesource is established so this command is not required.  What appliance (switch, router, ap, etc.) are you using this command on?
