NVRAM problem
dstecnologia
Community Member
When I try copy or save something in the startup-config archive, it's returned the following message:
"%Error opening nvram:/startup-config (Device or resource busy)"
What can I do to resolve this problem?
Jon Marshall
Jon Marshall
Have a look at this document which should hopefully sort you out.
http://www.cisco.com/en/US/products/ps6350/products_tech_note09186a0080202612.shtml
Jon
Thanks Jon!
With this document I've gotten resolve my problem.
guruprasadr
Level 11
Level 11
HI, [Pls Rate if HELPS]
Pls find the attachment for CISCO TAC Solution for such Error.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
