NX-OS 5k 5672UP replacement model
romanroma
I have reviewed the Cisco website; however, I am not able to find a direct migration path. I need to replace "5672UP", but I no longer see the 5k line offered. Does anyone have resources for a migration path? I have a few 5k switches that are different models I need to replace, but no clue what is comparable. It looks like the 9k replaced the 5k; however, I always thought that was a different model for different design goals.
Thank you.
pman
Attached a link that includes Replacement Product Part Number:
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/eos-eol-notice-c51-743752.html#Productpartnumbers
In some product part number section you can see that Cisco's answer is:
"There is currently no replacement product available for this product."
In this case I would recommend you to map the features you use / would like to use in the future,
here Cisco Feature Navigator can help you find a product that is compatible with your business requirements
https://cfnng.cisco.com/browse/switching/features
pman
marce1000
 - You may also go here (if you are looking for solutions in the datacenter , amongst others) :
                   https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
