NX-OS (Nexus 7k) to block/filter traffic between vlans.
navnath.dighe
I am working on a solution to block traffic between two vlans communications. . When I tested connectivity between vlans,  traffic is passing. I have configured VRRP protocols for l3  vlans  and 99 vlans  created on nexus7k. Please guide me how to block/communications between vlans.
balaji.bandi
show us your ACL or configuration how you have configured. simple ACL should deny the traffic between VLAN
check below thread:
https://community.cisco.com/t5/switching/vacl-on-nx-os-nexus-7k-to-block-filter-traffic-between-hosts-on/td-p/3953569
BB
you can use access lists or Vlan access list (VACLs). VRRP adds a bit of complexity, as you need to allow UDP port 8888 (that is the port VRRP uses as far as I recall).
