NX (programmable) & yum telemetry
sendalot7
Struggling to find/install/activate telemetry on NX.
    "http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/programmability/guide/b_Cisco_Nexus_9000_Series_NX-OS_Programmability_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Programmability_Guide_7x_chapter_011000.html#id_39852"
 says I need to find a rpm for it but I'm having no luck.
Anyone had success with this?
    NX9K-2(config)# feature tele ?
    % Invalid parameter detected at '^' marker.
    NX9K-2(config)# feature bash-shell
    NX9K-2(config)#
    NX9K-2(config)# end
    NX9K-2# run bash
    bash-4.2$
    bash-4.2$ ls /rpms
    bfd-2.0.0-7.0.3.I4.5.lib32_n9000.rpm    lacp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm      rip-2.0.0-7.0.3.I4.5.lib32_n9000.rpm
    bgp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm    lldp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm      snmp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm
    eigrp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm  ntp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm       svi-2.0.0-7.0.3.I4.5.lib32_n9000.rpm
    eth-2.0.0-7.0.3.I4.5.lib32_n9000.rpm    nxos-ssh-2.0.0-7.0.3.I4.5.lib32_n9000.rpm  tacacs-2.0.0-7.0.3.I4.5.lib32_n9000.rpm
    fcoe-2.0.0-7.0.3.I4.4.lib32_n9000.rpm   ospf-2.0.0-7.0.3.I4.5.lib32_n9000.rpm      vtp-2.0.0-7.0.3.I4.5.lib32_n9000.rpm
    isis-2.0.0-7.0.3.I4.5.lib32_n9000.rpm   repodata
    bash-4.2$
I was able to locate `/rpms` in bash mode so far.
Sam Byers
The switch is running  7.0(3)I5(1) or newer?
(7.3.1.D1.1.1) any clue on how to retrieve RPM(s) for nexus would be great!
Thanks.
