NX7K Double-Sided vPC
zekebashi
Level 4
Level 4
I am redesigning our DC and had a question regarding vPC in a dual-sided vPC configuration. The document below states and shows that when configuring dual-sided vPC, a NX5K or pair for redundancy is required. My question is, do the intermediary switches have to be NX5Ks or would the C4500s type of switches would work?
Thanks in advance.
~zK
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Yes, you can connect the 4850 directly to both 7ks and that should work just fine.
5 Replies 5
zekebashi
Level 4
Level 4
Double-sided vPC is configured when a pair of Nexus switches is connected to another pair of Nexus switches. In my design, I will need to have 2 NX5Ks to connect to the NX7Ks vPC pair.
https://learningnetwork.cisco.com/docs/DOC-23972
Thanks for the reply, Reza!
I am thinking of connecting a C4850 switch directly to a vPC pair(NX7Ks).  My question is, is this a type of design supported?
Thanks in advance.
Thank you!!
