NX7K L3 vPC
zekebashi
Level 4
Level 4
We have a pair of NX7Ks and they are configured in a vPC. We have a requirement to connect the pair of the vPC peers(NX7K_01 and NX7K_02) to a Router using a L3 Port-Channel and use sub-interfaces on this port-channel.
The doc below under the "Layer 3 over vPC for F2E, F3 and M3 Modules" section discuss the use L3 over vPC.
Our NX7Ks are on NX-OS 8.4(3) and using N77-M3448XP-23L modules.
My questions are
   -  Does the NX7K support L3 vPC?
   -  If so, does the L3 vPC support sub-interface configuration?
Example of configuration NOT tested yet:
NX7K_01:NX7K_02:
interface e1/1 interface e1/1
no shut  no shut
vpc 10  vpc 10
interface e1/1.200   interface e1/1.200
ip address 192.0.2.2/8   ip address 192.0.2.3/8
encapsulation dot1Q 200   encapsulation dot1Q 200
hsrp version 2   hsrp version 2
hsrp 200   hsrp 200
authentication md5 key-chain hsrp-keys   authentication md5 key-chain hsrp-keys
preempt   ip 192.0.2.1
priority 110  !
 ip 192.0.2.1
  !   interface e1/1.201
interface e1/1.201  ip address 172.16.0.3/16
ip address 172.16.0.2/16  encapsulation dot1Q 201
encapsulation dot1Q 201  hsrp version 2
hsrp version 2  hsrp 201
hsrp 201  authentication md5 key-chain hsrp-keys
authentication md5 key-chain hsrp-keys  ip 172.16.0.1
preempt  !
priority 110
ip 172.16.0.1
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/interfaces/config/cisco_nexus7000_interfaces_config_guide_8x/config-vpcs.html#concept_F862A25175DE4C738065F0EDA6F5D8C0
Thanks in
7 Replies 7
Mark Elsen
 FYI :
        https://community.cisco.com/t5/data-center-switches/l3-port-channel-to-nx7k-vpc-domain/td-p/3899489
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Reza Sharifi
L3 VPC should be supported but if you want to use a subinterface with a vpc and a Portchannel, the config needs to go under the Portchannel interface and not the physical interface.
Guidelines and Limitations for Layer 3 Interfaces
Layer 3 interfaces have the following configuration guidelines and limitations:
  • If you change a Layer 3 interface to a Layer 2 interface, Cisco NX-OS shuts down the interface, reenables the interface, and removes all configuration specific to Layer 3.
  • If you change a Layer 2 interface to a Layer 3 interface, Cisco NX-OS shuts down the interface, reenables the interface, and deletes all configuration specific to Layer 2.
  • Configuring a subinterface on a physical interface that is configured to be a member of a port-channel is not supported. One must configure the subinterface under the port-channel interface itself.
Regarding the third point. I'm curious, can the same be accomplished on a VSS (a pair of C6509s)? Do you happen to have a document to explain the steps to do that?
Thanks in advance,
~zK
Correct, I see this:
sometimes it is software-dependent.
• Subinterfaces cannot be created on Layer 3 EtherChannels
I found this old post(I posted it and totally forgot that I did)... You can create sub-interfaces on a L3 Port-channel/Etherchannel on the NX7Ks. I have never configured a vPC on a L3 Port-channel with sub-interfaces. This is what I want to figure out.
https://community.cisco.com/t5/switching/l3-port-channel-sub-interfaces/td-p/3025548
Apparently, you can also create L3 Port-channel/Etherchannel with sub-interfaces on VSS. The configuration would be the same:
interface Port-channel800
interface Port-channel800.90
encapsulation dot1Q 90
ip address 90.90.90.1 255.255.255.0
interface Ten1/0/30
no ip address
negotiation auto
channel-group 90 active
interface Ten2/0/30
no ip address
negotiation auto
I had a discussion with Cisco TAC and they stated that L3 vPC is not supported. Do you have a documentation where it says it does?
Best, ~zK
